sam un ont
The problem I am having is that the pto will not engage without grinding and the pto when engaged will slow down but never completely stop with the pedal depressed
I have adjusted the pto clutch and the pedal free play with no success
I have found that while cranking the engine (without starting) I can depress the clutch and engage the pto without grinding, let the pedal up to turn the pto, and then depress the pedal and the pro will stop
With the engine off I can engage the pot depress the clutch and then freely turn the pot
The problem arises once the engine is running
Any help is greatly appreciated
Sam
Sam
