MH22 transmission mainshaft oil seal
CharlesTx
Location
Central Texas
My MH22 is leaking grease where the driveshaft enters the transmission. Does anyone know the oil seal number? The shaft has quite a bit of side to side movement. Any way to tighten the bearing? What is the bearing number? I picked up from this site that the jam nut has left hand treads and the treads have punch marks that need to be slightly drilled. I do have a service manual but I can't find where this topic is covered. Thanks
Looking closer at the service manual I should be able to take slack out of the bearings with the jam nut. My question is does the bearing cage need to be removed to change the oil seal? Again does anyone have a number for the seal?
