TractorLinks.com
Show Parts for Model:
Re: MF 165 Front Wheel Wobble
DavidP, South Wales
05-16-2018 13:11:36
As Donovan has mentioned the tie rods are the first item to look at. next you should look at for any unnecessary movement in the main vertical shaft. The bushes and or shaft are likely to be worn. Check both ends of the drag link and check for play in the steering box. If power steering have an assistant move the steering wheel back and forth and look for play everywhere in the mechanism except where the hydraulic spool is actuated. Some play is required here. What tyre pressures are you running at? For non-loader work 20-25psi should be adequate. Have you checked the tracking? Check at points halfway up the front wheels front and rear from one side to the other. The distance on the rear side should be 1/8 to 3/16" wider in the rear.
DavidP, South Wales
