135 - Coolant coming out overflow tube ONLY after shut off
nrowles
I don't think I used the tractor at all over winter. Didn't even start it for probably 3 months. First time I used it this spring I noticed that it was leaking coolant out the overflow tube when shut off. About an oz or two. Has done it the few times I ran it this spring. It does not leak anywhere while running, only after shut down and only out the overflow tube.
What are the things that can cause this and how do I diagnose?
Thanks.
(quoted from post at 15:49:57 05/13/18) Two things fluid too high in rad, tank or pressure cap bad traper
Makes sense. I was actually thinking it could be the cap. I would say it’s not the coolant level because it didn’t do it last fall and I haven’t added any since then.
If you have room mount a small recovery tank on it? When engine cools down it draws coolant back into radiator.
