Mf 135 hydraulic cover removal
chrisb62
New User
I need to remove the top cover. I just want to double check that i just need to remove that roller behind the right side cover? Once i do that i can lift the top cover?[/b]
Yes, you do. I've seen what happens when it's not at the dealer I worked for years ago on a state highway mowing tractor brought in for repair, it wasn't pretty..
(quoted from post at 04:34:04 05/11/18) Yes, you do. I've seen what happens when it's not at the dealer I worked for years ago on a state highway mowing tractor brought in for repair, it wasn't pretty..
Yikes. So there's nothing else that needs to be done before lifting the top off? Other then the bolts holding it down of course
I would pull the stand pipe and cover (or remote box if you have that) in addition to the roller. Just one less thing you are trying to get to slide apart when trying to be gentle.
