Ok after tearing down the motor to find out what made it stop abruptly then figuring out its in the trans because when i push the clutch in the motor will turn over. I put the motor back together and pushing the clutch in it will start so i could lift the bucket and tow the tractor into my coverall so i can work on it. I can see though the fill hole i have a Multipower issue due to cracking in the Multipower clutch. I don't know thats what stopped it but I know it has to be fixed. I got it split at the gearbox now i have to remove the lift cover so I can get the rear split done.
I found these clip pieces in between the engine/trans. Any ideas?
Also the clutch finger bolts seem to have quite a bit of wear I think?
And is this normal for these to be worn off?
The outer shaft rotates freely in neutral. The inner shaft does not. I assume its connected to my problem.
