Hi Everyone. I am having an issue with my Massey 255. It will not start. I had it hooked up to a spinner spreader planting some grass shut it off and went to start it again and nothing. Nothing at all. The starter does not engage or anything. The battery has been tested and is fine. I have tried to cross the starter and nothing. I have tried to jump the starter from the battery and nothing. I pulled the starter and tested it. It works fine. The fuses on the dash are all good. The ignition is brand new. When I turn the key, power gets to the starter and the circuit tester shows that the neutral safety switch is getting power. I have even tried to cross the neutral safety and still nothing. It will pull start just fine. It has always started immediately except for the issue I am having now. Any suggestions would be greatly appreciated. Thank you.
