massey 150 front pump
first I would like to thank everyone for the advice I've received on my 150 Massey. she's up and running , the loader works but like everyone told , it's slow and I mean bad slow. what size pump do I need to find to go on the harmonic balancer to be able to run this loader at a acceptable speed? And where would I find such a creature again to the people that gave me advice on the tractor thanks much. will try to get pictures loaded of before and after
The 3 point pump puts out around 4.5 gallons per minute, you need at least 12 gpm for the loader so you can actually get something done with the loader.
(quoted from post at 04:37:09 04/17/18) The 3 point pump puts out around 4.5 gallons per minute, you need at least 12 gpm for the loader so you can actually get something done with the loader.ok thanks ptfarmer do I have to have a exterior tank or can I use the hyd. that are on the tractor
Some loaders use the loader mounting frame for the "tank" for the hydraulic oil. For the ones that don't use the loader frame for a tank some people tap into internal hydraulic of the tractor, or you can use a tank.
Try calling Nolts Equipment in PA 717.776.6242. They sell only MF used and new parts. I'd get around 17 gpm front pump.
