massey 175 hydraulics
spitz
Hey guys, I just bought a baler that requires two hydraulics controlls. My massey 175 that I
typically bale with only has one. Is it possible to add one or do I need a complete new
control valve with two outlets. I see there are some kits out there but I am not sure how well
they work as someone told me I will need to have a diverter valve to shut off the three point.
Any help or advise from your experiences is appreciated! Hopefully spring shows up soon!
Do you have the 2 spool valve that sits under the right front corner of the seat and bolts to the rear end top cover or do you have a different arrangement for remote hydraulics? Does your 175 have Multi-Power and/or Independent PTO or does it have a 2 stage clutch?
Mine has the two stage clutch. It has the three point controls and one hydraulic control right in front of the seat on top of the transmission.
Dang! I knew there was something I forgot! I will get a picture tomorrow when I go back out to the shop. Just got it slipped back together after a new clutch. I need a three lever controll. One for the three point and two hydraulics.
