Barnes Pump
2tractors
I put the 204 Barnes pump on my TO35 to test it out. As soon as I jacked up the front and started the bleeding process this pump started leaking between the reservoir and the top of the pump housing. The o rings between the 2 are flat top and bottom. Anyone ever use round one's or find a source?
We've had some success with bulk round o-ring stock spliced with crazy glue on the 35 and 65 air cleaners.
That might work if you can't find the correct diameter rings.
