TractorLinks.com
Show Parts for Model:
message for David P South Wales
derwen1959
04-16-2018 06:27:49
an overdue update on the MF35 3 cyl with the new flat battery... I put a multimeter on the + battery terminal and lead and there was a high discharge and the discharge stopped when I disconnected the auxillary feed from the solenoid the leakage stopped.. at the moment the owner is happy to disconnect the battery when not used
DavidP, South Wales
04-17-2018 07:35:28
 Re: message for David P South Wales in reply to derwen1959, 04-16-2018 06:27:49
Hi, sorry for the delay in getting back to you. Having a cable potentially 'shorting' is not good. Have you checked that the cables are correctly positioned on the regulator box?
D - dynamo, E earth, A ammeter, F field coils in dyn. Electrical components should be disconnected one at a time to isolate the faulty one.
DavidP
T
steve19438
04-16-2018 07:41:59
i disconnect battery too. cheap and easy.
Phil Tibbetts
04-16-2018 07:36:24
Why not put a battery disconnect switch on it? I use them on all my tractors that don't get a lot of use.
