MF 175 clutch adjustment
Camozzi04
Ok guys steer me in the rite direction. So this is the 1970 Mf 175 diesel, six speed multi-power. It has two stages on the clutch. Now wether it’s independent or live Pto idk. It’s got three stages on the pto nuetral,ground,engine.
I split the Tractor in half which required me to remove the clutch pedal. Now reassembled I need to figure out the pedal placement and that it’s going to function correctly. Thanks.
Hi, assuming that the pto screws are
adjusted correctly there should be approx
3/8" free travel at the point where the
external clutch arm strikes the casing.
Check the pedal height that it is not
uncomfortably high. Some adjustment can be
made on the rod if it is. Check for wear in
the rod ends and pedal.
DavidP, South. Wales
