I was reviewing the clutch adjustment procedure after completion and came across this note which basically said:
Very Important to adjust clutch release levers with a new primary disc installed.
Adjust the release lever height with a new primary disc installed. If reusing a partially worn disc, the clutch should be installed with a new disc in place then make the adjustments. Remove the clutch assembly and install the partially worn disc without altering the adjustments.
I adjusted my fingers to .060 with the old disc in place.
Did i do something bad?
I'm about to go adjust the linkage since my pedal pivot came in and please don't tell me I need to go readjust the fingers.
I don't think I could take it. It was that bad.
