Two questions:
1) can someone explain the usage/operation of the three ports off
of the hyd cylinder? there is one on top, two on left. I'm currently
using the front left and top to raise and lower a disc and other
implements ... however there is usually a "lag" in when the
implement raises? due to the 3pt raising/lowering ... which
leads to the next ?
2) the manual shows there is an adjustment available to freeze
the 3 pt and just use the hyd for a pull behind implement. An
illustration on p43 of the operators manual has insturctions for
opening and closing the shutoff valve. It seems to say that the
hex nut is a locking nut, but mine seems frozen, and the slotted
plug inside also seems very difficult to turn ...
Any help, nfo with this would be appreciated, as I would like to
have a responsive pull behind. Thanks
leads to the next ?
