Massey Harris 30 Water pump seal
hymie2lt
Anyone happen to know the part number for the water pump seal on a Massey Harris 30 tractor with the F162 engine? Someone maybe have a parts book handy? Thank you for any and all responses.
Wayne
There are several different pumps used on Massey 30's, the older style had two separate bearings that are available at NAPA, the newer style had the bearings and shaft as one piece and the seals were different.Start with the casting numbers on the pump housing.
NAPA lists a reman. water punp for a Massey 30, part # WP598151 for around $90. according to the picture it looks like the right one.
Thanks for the info Mike....However I will be re-building this pump and just need the seal. Would like to find out the original part number if anyone might have a parts book?
Wayne
