bowtieboy77
I have recently purchased a MF 20 model front end loader at a auction sale and preparing to install it on to my MF 135. I noticed that the right side loader mount appears to double as a oil resovoir. Also the single 3 pos spool valve bolts directly to the mount but has been damaged and needs replaced. Will I even need to use the loader mount oil sump the tractor holds 30lt of available hydraulic oil will this be enough to operate the loader without using loader sump. My original plan was to install a divertor valve where the cover plate is on the top right of trans cover. from this valve I would run a feed hose up to a 2 spool 3position valve. A return hose would go from this spool valve back to return port on left side of trans. With my draft controls moved to constant pumping position this should supply the hydraulics needed to run the loader. Will this set up work? or will I have to incorporate the loader oil sump somehow aswell? I am assuming to use the loader sump I would need to run a aux hydraulic pump pulling oil out of the mount into pump to spool valve and return back to the mount resovoir. If this is the case is there any aux hyd pumps that I could run off the pto. I would prefer to use the existing internal tractor pump if at all possible.
Also if anyone is using a similar set up if you could post a few pics of the hydraulic connections and front mounting it would help greatly. The loader will only be used for driveway snow removal and the odd top soil job. So it wont be working to hard.
