On the Z134 gas engine with power steering, when removing the pump the back one of the three bolts is very aggravating to get at. The radiator hose routs right by it and blocks it.
Here's a little hint for getting at that back bolt. Take a ratchet strap and pull up a little on that hose and it will clear enough to get a socket on that bolt. I figure that every little hint that saves some aggravation is worth posting here. Here's a picture with the ratchet strap on the hose. It's easier than removing that hose.
