I have a 1971 MF135 that I just had to replace the clutch and now I have issues with the power steering. Now that I have everything hooked back up, the steering either goes all the way to the left or right. I can barely touch the steering wheel in one direction and is will go to the end stop. At times steering wheel will just bounce back and forth and it is almost impossible for me to hold it still. I filled the pump reservoir with fluid and bled the air out multiple times with no success. When the engine is stopped, I can turn the wheel with no problem. I'm thinking the problem may be with the control valve on the steering column, but it appears I will have to remove the steering wheel to even access this. How can I verify if the valve is working correctly? Another option I considered is just taking the pump off and operating it with manual steering. Are there any issues with this approach? I just need my tractor and am tired of fooling with the steering. Everything worked fine before I replaced the clutch.
