MF290 (over filled hydraulic/transmission)
LJS30
Hey guys I over filled my hydraulics and now fluid is coming out the check dipstick. Should I drain until fluid is appropriate or will it simply be okay once it reaches the correct level? Will I blow seals?
Hi,
Absolutely YES! With the oil level too high you run the risk of oil
running into the clutch housing or out of the outer axle seals.
DavidP, South Wales
