Is there a gas engine to swap for a 3.9 / 236ci motor ?
marlin54
Looking at a massey 50 backhoe with a wore out 3.9
Perkins. Is there a gas motor that will swap into it ? Thanks
236 gas would swap in but you'd need to get a different key switch and rewire some things. I can't think of any reason to go with the gas over the diesel though (Maybe $$$ but there can't be that big of a gap). The 236 diesel is a solid motor and parts are readily available.
Guys i know this is older but i am hoping you can help. I have a massy 255 with a gas 212 in it. I either need parts for my 212 or maybe could do an engine swap. Can one of you tell me if a diesel will bolt right in or if it would be a major ordeal to swap out.
