I saved my 135 from salvage 20 years ago. I just recently decided to put it to work. Engine, trans & steering work great. I have changed all the fluids and filters. When I started it, the lift arms went to the top and stayed there. With the inside lever set to transport, the draft control lever has no control over the lift arms. I pulled the + hyd. pressure port plug out, (engine not running), oil shot out and the lift arms dropped. I replaced the plug. I set the controls to transport and down, started the tractor and the lift arms raised and stayed at the top with the tractor both running and not, quadrant & lift controls in any position. They will not come down. Also, when the arms hit the top, I could hear a faint, high pitched squeal which tells me the valve control is stuck in the "raise" position. Anyone that can check my theory & give me some ideas of where to go from here...that would be great.[/u][size=18:cf52108c98][/size:cf52108c98][size=12:cf52108c98][/size:cf52108c98]
