What is multipower
I always here ever one with a massey say something good or bad about multipower.
What is it?
How does it work?
When do you use it?
Most tractors i am use to have a high and a low.
Thanks
Multi power makes the six speed a twelve speed. Basically a hydraulically run over drive. An auxiliary pump pressurises a clutch pack that engages another set of gears. I personally like it. You can shift up or down a gear by flicking a lever on the dash. It also gives you a much faster road gear. You just have to be careful on hills. Tractor will freewheel with the MP in low.
