Hay hay hay
I am looking for some advice on putting LED headlights on an old ugly MF65 work tractor. The lights will be used on a very limited basis...30 minutes max..4 or 5 times a year.
Situation: When I bought the tractor the old headlights were gone, totally missing, and the wires to the original lights had been stripped out of the tractor. Also, the ignition switch and the push button start switch had been replaced with an after market key turn ignition switch (running thru the neutral safety switch).
I want to put 2 LED headlights on the tractor with a fused on/off switch. The question is where to hook the positive wire to have power? Regulator? Solenoid? and What size wire and fuse do I need for the Led headlights?
