Having trouble with my power steering pump. It's dumping a whole reservoir full of oil in a couple minutes engine running time.
It's a brand new pump so the seal before the drive gear should be good. The old pump leaked oil past the seal. So, I bought a new pump. It never did work quite right. Sketchy or jerky power steering. I can't find any leaks on the PS system. My engine oil seems like it's going up. But as I said that seal and pump are brand new.
Check the pictures below. You see the discharge from the bottom of the pump and you see where it hooks up to the steering. Are these hoses connected correctly?
