165 spool valve seals
can someone point me to the part numbers for the 3 seals between the top cover and the remote valve. They dont seem to be listed with the lift cover on agco. not sure if they are square cut rings or just orings that are smashed.
Found the reason for the leak one of the seals was missing and someone tried to seal it with silicone.
(quoted from post at 19:24:52 03/15/18) can someone point me to the part numbers for the 3 seals between the top cover and the remote valve. They dont seem to be listed with the lift cover on agco. not sure if they are square cut rings or just orings that are smashed.
I believe the biggest gasket for the top cover is purchasable through yesterday’s tractors. Under $2.
Can I get you to reply to my E-mail? Bottom right classic view. I may have the O-rings, but need to confirm which valve you have.
Wayne
