First 35 diesel
2tractors
Just bought my first 35 diesel 2 stage. Had to pull it onto trailer but got her going with a shot of either in the air intake. Everything seems to work but lift seems to work backwards from all my other mf's as the draft up controls lift. All my others I keep draft down and use closest control for lift. It has a loud clunk coming from left rear spin out wheel. Any ideas? Not loose lugs.
Three point controls on 100 series and newer were changed from the 35,50,65, and 85 models. If wheels have the cam lock over center blocks there still could be one loose that's not locked right, making the noise.
Went out and shook wheel and cam locks are loose, just knew it was something in the trumpet thanks.
Oil filter is a Great upgrade........:)
rear spin out wheel..........................:)
Bob..Owner operator MF FE 35 X
Did not know that was an upgrade. Steering was hard and found left front upright wouldn't take grease so tomorrow it's time to rob my parts tractor. Bowl leaks along with fuel cutoff.I have a spare power steering sector and pump. My plan is to eventually pull my loader off the gas 35 and install on the diesel.
