MF245 Power Steering
I was moving some dirt this weekend with my 245 and one of the power steering hoses busted. Needless to say I had to drive it back to the barn with the rear brakes. The hoses seem to be crimped to the steel lines coming from the steering column. Is there a way to replace the hoses only or do I have to replace the hoses and steel lines?
If it were mine I would remove the whole hose assembly and take it to a place that repairs hydraulic hoses and have them make one for you. Did that for a 255 and it worked fine.
I just had mine done, recrimped new rubber sections. Several shops around here can make rubber lines but only 1 locally can recrimp the rubber/metal. If you are are in a bind maybe just get a rubber hose on it and keep the metal one to fix right later.
