TractorLinks.com
Show Parts for Model:
35 update
Brendon Warren
03-05-2018 15:32:37
Update on my new to me 35. I just drove it to the corner and back. The cotter pin in that break away coupler was gone. It let the coupler slide back and the high low gears move with it. I cleaned the watery oil out while I was in there and didn't find the old cotter pin. I wonder if it was left out. Thanks for all the help, I had about convinced myself that I would be splitting it. Next issue is the sticky lift arms. Piston moved with ease but the arms themselves needed to be driven down. I think if I attach some thing heavy and work it it should loosen up.
John Deere D
03-06-2018 07:06:01
 Re: 35 update in reply to Brendon Warren, 03-05-2018 15:32:37
MF 35 Hydraulic pump replacement..2017...
Bob...Owner Operator MF FE 35 X ..1963
shaeff
03-06-2018 04:31:53
When I rebuilt the hydraulic pump on my 35 Utility I had to remove the PTO stub to get the pump out. I took that opportunity to clean out the differential casing. I had the main transmission case spotless. When I looked into the diff casing, there were chunks of metal from the original hydraulic pump, and about 3/4" of thick grease like sludge on the bottom.
Took me the better part of 3 hours to clean it out. It was a huge pain in the butt!
Phil Tibbetts
03-06-2018 04:57:26
 Re: 35 update in reply to shaeff, 03-06-2018 04:31:53
That is where I find the most crap too. Everything seems to collect back there.
Phil Tibbetts
03-05-2018 20:19:40
Don't you wish every problem was that easy to fix. If you still have the top off take one of those telescoping magnets and reach towards the back end of the case and you may find the cotter pin. I would drain all the oil and thoroughly check the whole case bottom. Too bad to start using it and have that cotter pin get into the gears. IMO
Brendon Warren
03-05-2018 21:06:36
 Re: 35 update in reply to Phil Tibbetts, 03-05-2018 20:19:40
I fished around in there with the magnet and came up empty. I put the cover back on so all I can do now is hope for the best. I took a chance on this one and it looks like I got lucky. Not running and knowing it wouldn't move. I bought it and a TO 30 for $1200. I got the 30 running but it has a bad skip. I'm leaning towards a stuck or broken valve.
2tractors
03-06-2018 07:09:44
 Re: 35 update in reply to Brendon Warren, 03-05-2018 21:06:36
Jees Brendon what a steal 2 for the price of one. Is the 35 a 2 stage?
Brendon Warren
03-06-2018 07:53:54
 Re: 35 update in reply to 2tractors, 03-06-2018 07:09:44
It's a single stage. I was thinking I might sell the 35 and keep the 30. The 30 is in nice shape.
