TractorLinks.com
Show Parts for Model:
MF 35X Injector settings
Billy2k
03-05-2018 00:21:12
Hello, does anybody here know what type of threads it is on the MF35x injectors? Im gonna change nozzles and need to buy a test pump with correct threads to adjust the nozzles. What is the correct setting, I have read 122 bars, is that correct?
thepumpguysc
03-05-2018 13:59:48
 Re: MF 35X Injector settings in reply to Billy2k, 03-05-2018 00:21:12
The pop testers you get off ebay come w/ 2 lines that fit most injector threads.
12x1.5 & 14x1.5 your is a 12x1.5
John Deere D
03-05-2018 13:38:57
See attached pictures:
Injectors must be compatible to Fuel PUMP...psi...volume...etc, etc,
Bob..Owner Operator MF FE 35 X...1963 A3.152
Billy2k
03-05-2018 08:25:58
Thank you. I thought it was 1/2" unf, since the tractor is built in England everything is in inches, but obviously the injectors must have been made in another country then since its metric.
Dieseltech
03-05-2018 05:22:31
Injector inlet is 12MM X 1.5 thread pitch. With used springs a ten percent lower opening pressure is acceptable.
Billy2k
03-05-2018 08:40:20
 Re: MF 35X Injector settings in reply to Dieseltech, 03-05-2018 05:22:31
Dieseltech
03-05-2018 14:49:30
 Re: MF 35X Injector settings in reply to Billy2k, 03-05-2018 08:40:20
The CAV injectors are made in England too. Most common pump/injector connection years ago in the US was the 9/16 X 18 Ermeto sleeve fitting. Most common now is the 12MM X 1.5 and 14MM X 1.5 thread pitch, both have sixty degree cone seats. Allis Chalmers were the last to use the old Ermeto pain-in-the-arse sleeve line ends.
