What is the auxillary pumping position?
Which of the 2 smaller levers is the draft control lever ? What is auxillary pumping position? What position should the Hydralever be in to operate the auxillary cylinder?
Sorry, I am about nuts today. Still trying to get a post driver working on a Massey Ferguson 50. I have tried about every position of all three levers I can think of and no pressure to the port on left front of hyd cover.
If the three point works OK, then with the auxiliary valve feed line connected to either left or right front lift cover port will work. Place the small moveable DRAFT lever up high as possible to turn on the pump inside full time. Lift arms need to raise first BEFORE the valve will be pressurized though, so you may want to block them up high anyway. Also may need the loosen the draft limiting range stop to get the draft lever high enough to work, if it's too low the pump won't be on.
With all 3 levers raised to top position, when I pull the lever on the post driver the 3 point lifts to its highest position, taking the lever almost out of reach, but the post driver still does not operate. It would be impossible to operate in this high position anyway. I am sort of at wits end. Besides wasting over $1000, now I have pulled a muscle in my back. (whine, whine, sniffle). Any ideas?
