Massey Model 65 Diesel UNDM 704769
So how does this master control spring retainer nut come out?
No blue wrench available, plus I'm unwilling to cut something I don't have a replacement part in hand.
I removed the grub screw at 3 o'clock, the "special" cap screws, and the control spring retainer nut refuses to move after a couple of mighty whacks with a 4 lb hammer and a punch, and I let it soak for a while in penetrant as well. I'l have a new boot for it that I can't install. Such is life... maybe someday.
I don't think the pin spanner would hold up the beating on the wrench to get it loose. 54 years of rust says NO.
The play in the master control spring is about 3/16, maybe a little less. Considering I'm only going to bush hog and scrape the driveway, I'll just let it ride the way it is.
Its not gonna hurt anything is it?
Attacched spanner picture courtesy of DavidP,South Wales.
I blew it up a little and tried to sharpen it so you could read the dimensions better. It was way too small before.
