massey 1100 gear noise
coatham
i have a 1970 1100 and the gearbox seams noisy especially in high multipower if you put high /low in neutral at tickover speed you can hear a lot more gear noise in high mutipower than low multipower is this normal or is there a bearing or something failing the noise seams to be towards the rear of the gearbox are the transfer gears
normally noisey ? any help apreciated
