dexterfarm
I am a little confused as to why the 3 point works this way. It has an accessory valve on top of the cover that appears to be to be
original. It has 2 levers and one set of remotes. the right side has the remote hoses but the left lever has caps on the outputs
and is what controls the 3 point raise and lower. along with the draft and position control levers. shouldn't this lever be for a
set of remotes and not to control the 3 point?
