fosterdave37
So I've had recent posts about ice in hydraulics. All cleaned out new oil clean filter. With the tractor running the draft control will move the vertical lever however the control valve lever wont follow it as I believe it is supposed to and position control does nothing. The hitch will move up if i manually push the control valve lever toward the back of the tractor and stay up as long as I don't touch the controls. Does slowly settle back down.
from what I've gathered I have a stuck control valve?
Do I need a new pump?
Thanks for helping the nebie with his first tractor
