Dealing with a non functional pto on a MF85. PTO spins in ground drive, but nothing in engine drive. Doesn't matter tractor rpm of idle, or full throttle. Engine pto worked well before the machine was parked a few years ago.
Filters and fluid( was bad shape) have been cleaned/replaced, as well as PS filter and screen. Power steering works "good."
When I move PTO lever from neutral to engine, or ground over to engine I feel no real resistance or click. I suspect that is normal given the hydraulic nature of it.
I realize my next course of action is to probably split the tractor. But is there any possible thing to look into before then. Possibly a cover,or plate I can remove to potentially get into the pto/relief valve and associated lines to clean/inspect before I have to split it? If so, where?
I wouldn't think that the PTO clutch is fried, but I am curious as to if the PTO brake could be stuck on if hydraulic pressure can't get back there to release it?
Thanks
Thanks
Thanks
Thanks
