Massey 65 Diesel Model Utility Chassis
Power Steering/ Power Assisted Steering/Whatever
I am going to plan B and removing the steering arm to get the tie rod end out of the steering arm spigot.
I have heat and beat and hammered to no avail, tie rod end has not budged.
I loosened the bolt on the main steering arm and it dropped down to the frame; I can see the master spline on the pedestal shaft.
Plan B
Remove the drag link and hang it out of the way. May have to remove the breather to get it out of the way.
Cut off the tie rod end so the 3/4 nut is still intact, that is to cut it just above the ball. Remove the tie rods both right and left. They are already loose now and just hanging by the stuck/frozen end in the arm spigot.
Remove the power steering cylinder support bolts.
Remove the pedestal assembly bolts.
Lift the entire assembly until the main steering arm clears the pedestal shaft. I need about 1 1/2 - 2 inches to get the steering arm out.
Once its out I can get an impact on it or take it to the machine shop to get the end of the tie rod by whatever means necessary.
Questions
Does the main pedestal have a spigot on it that sits down into the frame it bolts to? There's only 2 bolts on it. I removed those and can't wiggle it. Rust got me held in place?
Does this sound like it will work?
What am I missing?
Plan B
Questions
What am I missing?
