Cormiers Cove
I am wondering if anyone knows if the fuel lines on the MF 35 diesel tractor have flared ends? The lines from the heater reservoir going into the intake heater and the one from the reservoir to injection excess overflow T pipe?
I made a few new fuel lines with brake line of the same diameter and used new brass sleeves but I still have leaky fuel at my intake manifold heater and at the small fuel reservoir near the fuel tank. The female fitting at the T fitting for the leak off injector pipe is also leaking. It seams wherever I put a new brass sleeve on my new made fuel lines are the issue.
My brass sleeves don't seem to be sealing good.
My original fuel line going into my lift pump from my primary filter also leaks at the lift pump despite putting a new rubber olive. This pipe had an original rubber olive and I put a new one on but again leaks.
These are old photos to let you know what I'm asking about
