65plymouth
Need a bit of help as I am really considering buying my first tractor.
I am looking at a 1978 255. Unit has unknown hours but appears to be in good shape. Oddly enough, it doesn't have the rattle can paint job that you see on most older used tractors. I have looked at hundreds online over the last several months.
Can someone tell me what year Massey started putting wet discs in the 255? I confirmed that this tractor does have the larger 236ci engine and no multipower but am unsure of the brakes. Is there a way to tell if if has wet or dry just by looking at it? I have read that some "notches" in the rear end are a sign but not sure. Not sure where the notches would be located.
Tires are loaded on this particular tractor. Forgive me for being a greenhorn, but are loaded tires generally an indication that the tractor once had a FEL?
*****This tractor is 9 hours from me so I may have it shipped. What should I be leary of? It is being sold by a dealer with a reputation to uphold so I feel a bit better buying from a dealer than some guy on craigslist..
Any know issues with the 255? What else should I have this guy send me pics of. What are some known things to look for? I have video of it running and it seems smooth without smoke. T It appears the front wheels are moved way out. They are obviously adjustable, but I have no clue how hard it is to move them back in.
Thanks for the help.
