dexterfarm
just bought a MF 165. So I do not know the history of the tractor. It has a pto pump that runs the loader. I did have the lines to the pump off they were not routed well and the pump was not mounted securely. I did add quick connects in both the pressure and return lines. The loader is real slow to move and after a while the fluid foams out the vent. The fluid is not low. I thought it would work the air out I have run it a few times several days apart. Do I have a pump problem or could their still be that much air in the system? As much foam that has come out I would have thought the air would be out by now.
