1964 Utility model 65, UNDM serial prefix.
The headlights worked briefly, then the right light went out. I'll pull it to check for continuity. I'm betting its old and burnt out like me.
The rear work lamp works fine.
I did forget to install my 20 amp fuse for the lights.
My fuel gauge only goes to 1/4 and thats it. A visual check showed the tank nearly full. Whats up with that?
I'm going to pull the sender to check it, maybe tomorrow weather depending. The fuel tank senders are about $80 bucks a pop.
Temperature went to about 180 and held after warming up. That's with a 7 psi cap, I couldn't find a 10 psi cap locally.
I don't know what thermostat temp is supposed to be.
My tachometer/tractormeter does not work. Its new and so is the drive cable. The cable is not kinked anywhere. Part number 193167M91 with cable part number 506334M91. This bears investigation. Its a female square drive at the rear of the engine the cable fits in. I could see it with a flashlight. Something is not meshing as it should.
There is a little plastic bushing gewgaw in the tractormeter end of the cable. What does that thingy do, what is it for?
The one wire alternator works fine. On startup it comes up when the oil switch closes and holds about 2 amps to the discharge side at 14.7 volts. After run a little bit voltage comes down to 13.5 Vdc. Still shows a 2 amp discharge though. Could just be the gauge. Also I'm not sure of the battery condition, Its an old battery, original to the tractor from when ever. Amps deflect more to discharge when the lights are turned on.
Oil pressure started at 80 psi cold and after warm up came down to about 55 psi.
I'm going to get a digital tach reading at idle later while I'm fooling with the tractormeter.
Still got some bugs to work out, but its getting there.
Thanks to eveyone here for their help. What a knowledgeable group of people!
