Best way to flush power steering system
Caryc
I have a MF202 with the Z134 Continental four cylinder gas engine. What is the best way to flush the power steering system?
(quoted from post at 17:02:37 02/15/18) I have a MF202 with the Z134 Continental four cylinder gas engine. What is the best way to flush the power steering system?
I'd take the return line off, stick it in a bucket, fire up the tractor, and use a squeeze bottle to keep the reservoir full while a helper turns the wheels lock to lock at low idle. When you see nice clean fluid come out, I'd say you're probably good to go.
(quoted from post at 14:11:34 02/15/18)
Thank you, that's so simple. Why didn't I think of that. I guess I was thinking there had to be a more complicated way. :wink:
No problem! I'm often guilty of over-complicating simple tasks as well!
