Yesterday I got a phone call from my father stating that the clutch wasn't working on our 175. He said it just popped and then the pedal goes all the way to the foot plate without disengaging the clutch. He stated that the linkages from the clutch pedal to the shaft are all there and the shaft rotates when putting pressure on the pedal. He said it doesn't take any effort to push the pedal down like it did before but the pedal does rebound back up. The tractor never had any clutch issues prior to this event. I haven't had time to pull the inspection plate and look it over yet, I figured I'd put out an S.O.S on the forums while I'm out of town.
The tractor is a 1965 MF 175 Diesel
Serial - SDW644002645
Thank you.
Thank you.
