Massey furgeson doesn't move after lift WHY
Superhero
New User
U have a masey fugerson mf2RIS used lift to raise spinner wheels ,the spinners dug into the ground and pushed tractor .I heard loud noise. Now the tractor goes in gear but doesn't move.Not sure name of spinner.
I'm not familiar with that model of tractor , the symptoms you mention sound like you may have broken a shear pin on the transmission shaft .
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=804042
Hello, I would agree with Charles, it's not a model that I have come
across before. Normally when this problem occurs it is due to the
sheartube breaking in the drive line. It is a sleeve mounted on the
output shaft from the gearbox and onto the pinion shaft. The sleeve is
deliberately 'weakened' so that it will shear if an excessive load is
placed on the transmission. They also fail of their own accord
occasionally.
Please clarify the model.
DavidP, South Wales
