Curious as to where I should look to drain/change the hydraulic fluid and filter for the 3 point and loader?
Also, where the power steering filter is, and where it is drained?
To get it all cleaned out I plan to drain and run some diesel in it, is that a good suggestion?
On an 85 I got running after several years of sitting, near the trans/range levers are what I think are two remotes, is it likely these would control the 3point or PTO? Can't seem to get 3 pt or PTO to move much at all, in all PTO ranges. On the loader itself (Dual brand)there are three levers. I assume bucket curl, raise/lower, and the 3rd I don't know. Can't seem to get the bucket to try to even do anything.
Thanks
Thanks
