Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Oil line?
jjgurley
02-07-2018 11:55:27
I'm still trying to get our inherited 245 running. While I'm messing about with the fuel system, trying to get fuel to the injectors, I have a small hose (1/4"?) that runs from an elbow into the block (behind the injector pump) that snakes back and eventually down to the ground, that is spitting oil, even with just turning the engine over repeatedly (as I look for fuel blockages). It's probably some sort of breather, but I doubt it's supposed to lubricate the grass. Where is it supposed to go besides my yogurt container?
ptfarmer
02-07-2018 16:57:25
 Re: Oil line? in reply to jjgurley, 02-07-2018 11:55:27
At least you know it has some oil pressure when its cranking.
jjgurley
02-07-2018 16:47:54
Oops! Thanks for the hint.
ptfarmer
02-07-2018 16:23:45
Hook that up to a oil pressure gauge.
MF#1
02-07-2018 13:55:48
Be glad you haven't got it running;-) I believe that is the line that goes to the oil pressure gauge in the dash, it should be pointing up not down. Look behind the battery towards the dash and see if you can see the other end going to the gauge. Need to get it connected before you get it running or bad things could happen.
