My 180 has been lazy in lifting the 3pt for years so i investigated. with the hydraulic cover plate that holds the rock shaft off, i discovered a pipe that supplies fluid and pressure up to the rock shaft. On that standoff pipe there is a block that is 1/2 X 1/1/2 X 1/3/4 that is attached to the pipe but under testing it shows that the pipe bleeds pressure back to the trans. So does anyone know the purpose of this block.
next question I am eliminating the use of the piston pump and removed all the control linkage so is there any concern with that??
