I have a Nippondenso model 8162 35 amp one wire alternator to use on my tractor when I get a bracket fabbed up. My question is about the wiring.
There is a switched line coming from the back of the alternator. Does this go to the oil pressure switch where the red wire is pictured ... tells the alternator to start charging when the engine is running?
Charge wire B+ to start solenoid?
Should the voltmeter positive come from battery or solenoid?
Photo shamelessly stolen from ptfarmer
