MF383 loader hyd's?
Tx Jim
How is the best method to attach loader hyd valve to hyd system? My neighbor would prefer to not utilize the rear breakaway couplers to supply hyd's to loader.
Thanks,Jim
Thanks for reply. So does factory hyd system lack enough flow or have no good method to attach ind valve to operate a FEL just to handle rd bales?
Biggest problem with the factory hydraulic pump is low flow rate making loader response slow. I am assuming this model has the standard MF hydraulic system.
You should be able to bolt on a hydraulic pump directly to the front axle support of the 383 (they use a 17-21 gpm pump), then all you need is the pump drive that bolts to the front crankshaft pulley.
What year is your 383.
