bowtieboy77
I posted a thread almost a year ago about a 135 perkins gas hardly running even after a massey dealer billed me $800 to repair. As a quick back story the points welded togeather. I replaced points , condenser, plugs, cap and rotor, rebuilt carb and could not get it running properly. Massey dealer replaced all the above, and tore carb apart again, also installed a coil requiring a ballist resistor and ballist resistor. It ran good for a few days then went back to the way it was before (hardly run, back firing only run with choke on) I was very frustrated so I left it in drive shed until a month ago. I disassembled carb again and checked float height. I got it running and have been setting timing.
After engine is warmed up my idle is 850rpm and timing set to 12 degrees BTDC. It idles fairly smooth but if I give it throttle to fast it will back fire a few times then clear up. If I hold throttle around 1800rpm it will back fire lightly once every few seconds.
If I slowly give it throttle it will increase rpms with no popping.
If I advance the timing to 30deg it runs slightly rougher but will accept throttlequicker. I also checked my advance by setting timing to 12 deg at idle then increase rpm to 2000rpms and rechecked timing and noticed its about 26deg which is per spec.
I think I am very close to having engine fine tuned just wondering if anyone has any suggestions as to why the engine will backfire when throttle is pulled to quickly?
