I'm having trouble getting the bush hog deck to stay at a constant level with a MF 245.
I've read the manual, but clearly something is not set correctly.
The land is relatively flat.
Initially, the deck is at the correct position with the back end slightly higher than the front end (nearest the tractor).
Shortly after moving, the deck slowly starts digging into the ground.
Any ideas on how to correct this ?
